Hi guys,
I posted a thread here about tossing up between a Silvia and EM7000 purchase. While thinking about it - a friend gave me his old Via Venezia which I thought i'd use to gauge my interest and learn a little about homemade coffee first.
Today I went out and purchased a Breville Smart Grinder Pro (BCG820). I figured that no matter what machine I end up using, i'll need to be able to grind beans. So I also grabbed some beans from the cafe up the road (love their coffee
As for the machine - it seems to be in good condition. I stumbled on this video yesterday which went on about how good the pressurised grouphandle is but, the top comment pushed strongly in the opposite direction. To quote:
So I opened up the pressurised group handle only to find that the valve was wrecked anyway - so i just ripped it out and cleaned everything up and attempted to make my first coffee. It was rubbish. Second one - better but still pretty average.
I followed the method above as close as i could but I still have to work out how much coffee to grind into the grouphead and how fine. Currently the grinder is set to 6 and 18 seconds. I don't have a proper sized tamper, the one i got with the machine is far too small so I have to tamper 3 or 4 times around the basket to flatten it. I'll look into buying a correctly sized one asap.
Also - from what I read, the steam heads on these machines are "Panarello" and make the milk far too foamy. I'm considering swapping it out for a steam wand as this thread suggests. What are peoples thoughts on this? Is there a way to reduce the foam by modifying the stock steamer wand or is it best to simply swap it out?
Mainly - I'm just wondering where I should start in fine tuning my extraction method? I was thinking I could film it and stick it on youtube for the experts on here to critique? Once I get the coffee extraction method, I'll move onto the milk steaming.
Anyway - any tips or advice would be awesome.
).As for the machine - it seems to be in good condition. I stumbled on this video yesterday which went on about how good the pressurised grouphandle is but, the top comment pushed strongly in the opposite direction. To quote:
WRONG WRONG WRONG... The pressurized portafilter using "table salt grain" ground coffee without tamping will never make anything but hot strong coffee, NOT anything approximating "real espresso". Making good barista quality espresso shots with plenty of crema even with budget brand Saeco machines is well within reach of anyone that owns a good quality bur grinder, (like the Rancilio Rocky). All you have to do is this:
1. Remove the pressurized valve from this portafilter (throw it away).
2. Turn on your machine with the portafilter installed (basket removed) to let the boiler and portafilter warm up for about 15-20 minutes.
3. Put your espresso cups or shot glasses on top of the machine to let them warm up too.
4. Grind your whole espresso roast beans to a flour like consistency.
5. Fill the portafilter basket with ground coffee so that it is rounded slightly higher than the rim.
6. Using a 52-53 millimeter tamper press down firmly and twist to make a well packed coffee "puck" in the basket.
7. Remove the portafilter from the machine, installed the basket with the coffee being careful not to burn your fingers, and re-install the portafilter into the machine.
8. Put a warmed espresso cup under the portafilter, turn on the machine, and start counting out 25 seconds from the moment the coffee begins to come out of the spouts.
