Hi,
I'm new here. Have tried the search and read the 'Breville BES820 issues' thread. Although it is also the steam function I think that my problem might be a different one. Would be great to get some help from more experienced members!
I bought a used BES820 for $20 from gumtree. The owner said that the steam doesn't always work.
I took it appart and here is what I could find:
The case of machine has lots of corrosion in the lower half. the wires look fine (pulled appart and put them together again. Seem to have good contact). The area around the chip seems like it hasn't got wet.
The steam works right after turning the machine on. The swich always does the 'click' and the lights change.
However, if the machine has been on for a while it still clicks etc but there is no steam (the pump won't start).
I also reset the program function. If I pour a shot (single or double) water starts running through for approx. 3sec then there is a break in that you can hear the 'ts-ts-ts' of the pump (?) and then water runs for another 4secs. with the normal pump noise. Is this normal? the manual pouring works.
Does anyone have an idea what could be wrong with it?
I am not an electrician (though I'd say, I can repair it if it's not too much to do)...
I am not planning on rebuilding it or spending much money on it either...
I just thought that if it is a small part or some cleaning in the right place I'd give it a go...
Thank you,
Paul
Thank you,
Paul
