I have a two year old Saeco Via Venezia that I use with a bottomless portafilter. The machine has recently started to struggle pulling shots to the point where I have had to adjust the grind size up. I should point out that I use a Baratza Encore. Thinking it might be a faulty ball valve, I changed it (as well as the spring and gasket). No change. I have also descaled and cleaned with Puro. The reason I suspect the problem is a lack of pressure is that when I start the shot the pump noise is regular for a few seconds and then it changes to almost the sound it makes if it chokes on too fine a grind; at that point if I open the steam valve for a fraction of a second it seems to give the pump a little more power (upon closing the steam valve). Sometimes one or two short burst like that seem to do it and the flow returns.
Other important elements:
Thank you for taking the time to read about my issue.
- I have used this grinder since getting the VV
- I use the same coffee 80% of the time. The issue is the same with my alternate coffee
- I recently adjusted the steam wand grub screw as recommended by Scooter in these forums (fora?)
