Need help confirming the correct non-pressurised filter basket for a Breville Ikon BES400... which is close to being replaced unless I can improve the resulting brew. I have an OK grinder( Breville Smart with shims(. What I've found is that when I grind coffee very fine the machine can't handle it..... which led me to the non-pressurised basket solution. My question is which basket, I'm confused between three:
About to buy one, but not sure which. Hoping someone can confirm the correct/best option.
- Krups 51mm basket
- BSWF100 basket set from Breville - looks correct but Breville tell me it is not compatible
- BES200/96.2 - The single wall basket advised by Breville, which strangely doesn't get a mention in forums
