Brazen Plus - Your Favourite Settings
  • #16
    Little off topic but didn’t think it warranted a new thread. Anyone know what the power draw the brazen plus has. Wanting to take it away for camping trips etc. will have 2x100amp lithium and a 1000watt redarc pure sine wave inverter What is the amp draw on it?
    • #17
      I found a couple of references to 1400 watts for the UK version.
      • #18
        rusty888 -- you could have a look at the sticker under it
        1400w is correct.
        1000w might be a bit tight. I've run it on a 2200w generator okay, I've not power profiled a Brazen but starting from cold it will pull more power than later in brew cycle (as heard from my little generator changing revs to suit).
        In an weirdly odd way of using it, you could boil a billy and tip it in the top and then use minimal power to release the water at the right temperature.
        I did similar while camping last weekend, I used the basket as a pour-over held on top of the carafe (ie: none of the electronics). Worked a treat to make a litre of filter brew that kept hot in the jug for the following hour for the second cups.
        • #19
          Originally posted by Andy View Post
          rusty888 -- you could have a look at the sticker under it 1400w is correct. 1000w might be a bit tight. I've run it on a 2200w generator okay, I've not power profiled a Brazen but starting from cold it will pull more power than later in brew cycle (as heard from my little generator changing revs to suit). In an weirdly odd way of using it, you could boil a billy and tip it in the top and then use minimal power to release the water at the right temperature. I did similar while camping last weekend, I used the basket as a pour-over held on top of the carafe (ie: none of the electronics). Worked a treat to make a litre of filter brew that kept hot in the jug for the following hour for the second cups.
          I hate to admit I’ve looked at the manual I got when I purchased from you but couldn’t find anything. Never thought of looking underneath the item.
