So a popular modification on the Gaggia Classic machine is to fit a steam wand from a V2 Rancilio Silvia, replacing the standard (and rubbish) panarello wand.
Whilst this is a good, easy modification, you are still limited by the wand only moving side to side and not being a ball jointed wand. An option is to fit a wand from a V3 Silvia however this can be quite expensive and requires adapters to make it work on the original pipe fitting on the Classic.
After pondering which route to take when refurbishing a Classic, I checked my spares bin and found a steam wand from a Sunbeam EM5900. The advantage of this wand is that it is a ball jointed wand with the swivel assembly enclosed in a brass case with a 1/4" male fitting on top.
The wand is a perfect fit onto the original Classic fitting. All that is needed is to remove the original o-rings from inside the fitting (if they didn't come out when you removed the original wand), add some teflon tape to the male thread on the steam wand and attach it to the pipe fitting.
Some bending of the copper pipe is required to fit the brass case of the wand inside the body of the machine. By bending the pipe to create some downward force on the wand, it is held firmly against the machine and does not move.
Performance is great with this wand, it's a good match for the Classic. It is quite long but it is easy to fit a large milk jug under it.
Purchasing one of these wands is difficult as there aren't really any spare part suppliers. You should be able to get a whole EM5900 fairly cheap though. I believe the EM6200 has the same wand although I'm not totally sure.
