Sunbeam EM4800c not pumping water - need help to prime!
  • Sunbeam EM4800c not pumping water - need help to prime!
    Post edited due to not being able to delete
    Can you manually operate the valve in the bottom of the tank and make the water come out (if you're anything like me you'll need a reminder to try this over the sink)?
      Hi level3ninja - yes no issues with the valve in the tank.
      thanks for the tip
        Did you get it working? Why the edit/deletion?
