Originally posted by Seraphim2017
View Post
Em7000 and bcg450 newly acquired used. What next!?
highly recommend the 820 over anything else in that range - it's not much more expensive. you want a grinder that has the ability to grind so fine that you can choke your machine - i.e. such a fine grind that water won't flow through it properly. you don't want something that is just useable at the finest setting, because this limits you with both your dose and the coffees that you brew, because some will require finer grind settings than others. this is why having a good grinder is so important - it really matters when it comes to espresso.
