Hi guys,
Im sort of new to this so unsure if im putting this in the right group. I have Breville coffee machine (150 bar) which I bought a few years back. I also have a the EM480 burr grinder.
Question 1: Im wondering what sort of temperature does the coffee need to be when its extracted through the machine?
Question 2: With different grinds on the EM480 will I get a different temperature when extracting coffee or should it be the same from coarse to fine grind?
Question 3: Would a higher bar machine affect the time to extract coffee? Is there higher bar machines out there?
Question 4: What is the optimum bar pressure for a machine? What machine would you recommend? Would the bar pressure affect temperature?
Whats actually happening is when I test just the WATER from the machine WITHOUT the coffee grind, I get a temperature of 70-75 degrees. When I extract a specific COFFEE (7 grams thats ALL i can stick in the portafilter basket!) I get around 38 to 40 degrees? A bit too cold for me!
Though its not the same with all coffees, some are in the 60 degree range when extracted. Mind you I DO NOT keep the coffee beans in the fridge and grind just few minutes before extraction. Would tamping and how I put my grind in the portafilter basket be a factor with temperature?
Can anyone point me out to a website that are worth checking out on HOW to make coffee?
Any help would be gladly appreciated.
Jacek
Though its not the same with all coffees, some are in the 60 degree range when extracted. Mind you I DO NOT keep the coffee beans in the fridge and grind just few minutes before extraction. Would tamping and how I put my grind in the portafilter basket be a factor with temperature? Can anyone point me out to a website that are worth checking out on HOW to make coffee?
Jacek
