non pressurised filters with breville 800
  • wattch
    Re: non pressurised filters with breville 800
    hi Crantock, do you remember what the part number was for the rubber ring. I recently bought the bar italia filter and am now having a simular problem.
  • crantock
    rubber ring replaced, tamper purchased, now I just have to perfect the grind and were off! Thanks for you help psaigh
  • psaigh
    Guest replied
    No probs, hope it all goes well. Keep us posted
  • crantock
    ah ha!! just did as suggested, rubber washer is completely perished. Trying to remove and clean shower head, back to breville for another spare part - thank you so much, will keep you posted
  • crantock
    the breville bar italia filter as recommended on the forum, fits snugly into the holder but then water and coffee spurt out. Tried no coffee, just water and starts off fine, but then starts to leak out, under pressure from the shower head, will try as you suggest and let you know. Thanks
  • psaigh
    Guest replied
    are you using the breville baskets or the krups ones? Either way it still seems wierd, maybe take out the rubber seal at the shower screen and give it a thorough scrub then re assemble (undo the screw where the shower screen is) and see how that goes.
  • crantock
    started a topic non pressurised filters with breville 800
    thanks for all the info on this forum. have had a breville 800 for ages but read about the non PF baskets on this forum, they arrived today.. Excitedly I made the first cup - coffee and hot water spurted all around the holder. Tried again with more tamping (using breville scoop/tamper - will get proper tamper tomorrow), same deal. Seems like the non PF basket doesnt quite seal properly, or is it to do with the black plastic in the bottom of the holder?
    Anyone else had this experience or have any tips for me? Look forward to your comments.
