Faema E91 Diplomat 2G
  • marvonn
    Re: Faema E91 Diplomat 2G
    Hey guys, anyone has a manual of the E91 with the red 4 digit display.
  • CaffeSilipo
    Hey C-Mach,
    Thanks, I know which button you mean & unfortunately it is the only button missing. I am trying to find someone up here on the Gold Coast that can help me. I will try to push it in with out the button for now and see if I can get anywhere.
  • C-Mach
    Mmm Faema Diplo nice machine which model .There is a button on the side top left grp next to display panel you must hold that in for about 10 seconds the machine should beep (if it dosnt beep it is locked on the main board)then you keep pressing the button to H 20 is displayed.You must always program your levels using freshly ground coffee .Now while it is on the h 20 display you will need to hold the coffee button until the desired level .If you programed the left grp it auto the right grp aswell.To get out of program mode you must hold the button down again until it stops beeping .Hope that helps if you have any problems you can pm your number and can do this over the phone.Are you in sydney forgot to check?
  • CaffeSilipo
    Thanks, Ill see if I can get a photo up. I know it is different to the Due, but Ill give anything a go.
  • ozscott
    Can you post a picture of your control buttons...it may be the same as the Due.. in which case I can help.
  • CaffeSilipo
    started a topic Faema E91 Diplomat 2G
    Hey Guys, Wondering if anyone has experience with this machine. I need to reprogram the shots. Would appreciate if anyone has a Manual or advice for this machine. Thanks
