Re: Rancilio Epoca S1 Help Please.....
Thanks for that.
Sounds like it is the element kicking in, which is quite normal. Once every 2 minutes or 3 minutes is what my expobar does for example.
There should be a click when it comes on, it should stay on few a few seconds and then another click when it turns off. Then nothing for a few minutes, it actually sounds right to me, the couple of clicks in the 30 seconds you hear is it coming on then off.
If you have boiler gauge, the clicks should match the top and bottom of the cycle on the gauge.
Hi all, I finally got my new machine on tuesday Rancilio Epoca S1 tank model. The reason for the post is that I am not sure if this is normal but the machine has a constant click noise, similar to a relay click every so often, sometimes 3 times every 30 seconds and other times once every 5 minutes........... Can anyone advise if this is normal?? In the past I had the same model machine but it was the 2 group plumbed Epoca and that had no clicks when it was on.
Thanks in advance.
DavidTags: None
