Programming a Bezzera Ellisse
  • nick_stevens
    Re: Programming a Bezzera Ellisse
    Another thing to keep in mind is that you can program both groups at once if you wish. I think it is the left group if you push the program button the right group lights will flash also and it will replicate the dose left to right. saves time and coffee
  • telemaster
    Thanks Dennis- Ill pass that on and have a look myself today
    Brett
  • Dennis
    Originally posted by 53424B424A4654534255270 link=1260475002/0#0 date=1260475002
    Hi All
    my work has bought an older Ellisse (needed new pressurestat and the usual tweaks, boiler still to be cleaned), but we need info about how to program using the volumetric buttons. Does anyone have an old manual, know links for one on-line, or is able to explain the basic process?
    This was for a small one group:
    1. Press and hold the continues dose button for 5 seconds and it will start to blink (not sure what the writer meant by this) :-?
    2. Press the dose button you wish to program and water will flow out of the group.
    3. Press the same dose button again when the water reaches your desired level.
    Is this the same process for larger commercials (two group in this case)?
    Brett
    Its the same process Brett. Blink=lights flash on/off. Dont forget you need to dose as per usual.
  • telemaster
    started a topic Programming a Bezzera Ellisse
    Hi All
    Brett
