my Bezzera machine is leaking from the group
  • my Bezzera machine is leaking from the group
    Hello All,
    I have a 2 group Bezerra 3000MP which has started leaking from the left-hand group. I turn it on, the pump goes for a few seconds, and then water drips through the screen at a reasonable rate. I suspect that there is a valve stuck open somewhere - but which one? Any help would be greatly appreciated.
    Thanks,
    Brett
    Re: my Bezzera machine is leaking from the group
    Could be the solenoid is not closing properly, do a backflash with out powder, and them one with powder this should clean the dust.
    Other wise, could be that re stricter or the filter on the top of the group head are dirty, you need to clean it up to allow the water to go freely.
    Any questions give a call or pm me we could try different things.
    Regards
    Renzo
      Thanks Renzo, I will investigate both of those potential causes and try the backflushing and then check the filters if that does not work.
      Brett
