PID with pre infusion
  • #16
    Re: PID with pre infusion
    Originally posted by 0A2E272724241E0A2E322C2E410 link=1270127553/14#14 date=1270207808
    Originally posted by 547B72706758747B74727078707B61150 link=1270127553/13#13 date=1270206568
    TWO switches.Off - ON
    Linked, so that Switch 1 is Element 1 and Switch 2 is element 2... But Switch two is linked to Switch 1.
    Will a similar switch like the one you are planing to use on the Della Corte work ?
    e.g. keep the current on off switch and use the new switch for the elements
    Would need to see teh cct.. Depending on how they do things.. Can mean a simple solution ior a bit of a fiddle. But either way... You have space inside :-)
    • #17
      Originally posted by 6F40494B5C634F404F494B434B405A2E0 link=1270127553/15#15 date=1270207930
      Would need to see the cct..Depending on how they do things.. Can mean a simple solution ior a bit of a fiddle.But either way... You have space inside
      So that means I can entice you with free coffee AM   ;D
      Edit: Also entice you with Greek sweets we just made for Easter
      • #18
        Originally posted by 0B2F262625251F0B2F332D2F400 link=1270127553/16#16 date=1270208741
        Send me the Electrical diag.. I will try to have a look.
        • #19
          Originally posted by 052A23213609252A25232129212A30440 link=1270127553/17#17 date=1270210193
          Send me the Electrical diag..I will try to have a look.
          I only have access to the expanded view of the mechanical parts for now
          I will ask Barazi to email me the Electrical Diagram if available and pass it on to you
          There is only a BZ35 Electrical Diag on there site
          • #20
            Re PI a delay timer on the pump is worth considering that would also allow line pressure to do the PI.
            • #21
              Isnt your power switch already a 3-position switch? Off-Autofill ON-All on
              Make sure SW2 is hooked up to the correct position on SW1.
              Java "Fun with electricity!" phile
              Toys! I must have new toys!!!
