Brugnetti or Technologica
  • maheel
    Re: Brugnetti or Technologica
    I have a 1 grp Brug 5L boiler commercial machine.
    Not sure if its a problem but the group head attaches directly to the boiler and mine tends to get a bit hot if left for a while and can need a solid flush or two. I have adjusted my Pstat up and down but found two low was "cold" but when it seems in the right spot if gets a bit hot and needs that flush.
    Check the plastic at the end of the area that surronds the group head (on the ends) mine is cracked and the support for this area (design) is quite poor and would be an issue on all of them if the same. They would snap right off if you tried to lift or move the machine by that area.
    parts seem easy to get
    I like mine and it makes pretty good coffee, commercially I am not sure I would buy one. I would be looking to a LM linea........ or other dual boiler
    but if its set up well and your beans and grind are good, excellent coffee can be made from mine
    this thread would be 3000+ if new.....
  • melbuurn
    started a topic Brugnetti or Technologica
    Guys
    I am looking at the two above machines - does anyone know or have one of these and are their problems?
    I am not sure of the model numbers, but the Brugnetti is 3grp and other 2 grp.
    Melbuurn
