Texturing milk w Alex Duetto ?
  • Texturing milk w Alex Duetto ?
    The Alex came with a 2 hole steam tip and plenty of steam, bit too much lol. What are people doing to remedy this. On the VBM (under the advice and guidance of CS people) I took the cover off and made adjustment to lower pressure and also went to a single hole tip. It was all good from ther on in.
    Would lowering steam temp help?
    Thanks in advance
    CB
    Re: Texturing milk w Alex Duetto ?
    Take off the tip. Thread a bit of copper or brass wire through the holes--thickness depends on how much you want to reduce the steam. Refit tip.
      Cheers Greg, I actually did the toothpick trick and it worked well for texturing but noticed the steam wand got hot from restricted flow ??
        The steam wand gets hot from the steam passing through it, and from sitting in hot milk. ;D
        Now that you know restricting the holes works, you can go for a more permanent fix than wood. Some have been known to have the holes silver soldered (food grade solder!) and then new smaller diameter holes drilled.
          Hi Chris,
          The Alex wand is excellent, but I suspect youre just not used to such good steam performance. In my opinion, it comes a very close 2nd to the Giotto wand which is the best in the business.
          My advice is to hang in there for a bit before you attempt any modification as youre going to get used to it really quickly. Try also dropping steam temp a degree or two as well.
            It took me plenty of milk to get used to big steam and a 4 hole tip (and toggle valves) after using home a smaller home machine. Even the weaker steam on the Pavoni and the 3 hole took a bit of sorting, tried plugging holes and eventually just learnt to live with it and adopt a method that works for the machinery at hand.
              the remedy is learning how to steam milk with a decent amount of steam power. perfect milk is not hard to acheive from a full commercial machine with 4 or 5 holes in a tiny 400ml jug... just keep practicing
                Try 150ml and 2 whole tip ;D
                  Yep- I have an 80 ml milk jug and texture with the 4 hole tip on the GS/3... It can be done!
