How do you tell when in-tank water softener needs replacing?
  • #16
    Re: How do you tell when in-tank water softener needs replacing?
    Hi.
    The mushroom is a component in the famous E61 brew heads.
    A quick google for E61 Mushroom will show you what they look like, and what they do. Numerous post here and elsewhere too about scale buildup on them, etc.
    • #17
      Hi
      Im not sure whether the Cimbali Junior has the same E61 mushroom arrangement. I understand it has some E61 elements but not all.
      Back to my original question, how do you tell when you need to buy a new in-tank water softener? Is it a matter of testing the water for hardness coming out of the water softener or is there other more visable means?
      • #18
        Originally posted by 14101E666B530 link=1297901145/16#16 date=1298011918
        Hi
        Ya taking it to the nth degree
        There are many variables - Be it TIME / FLOW / WATER / QUALITY of RECHARGE / Number of RECHARGES the beads can stand / Time its self.
        Thus if in doubt Change teh filter and look on the wrapper, it may have a use by date or a USE rate. Being extra careful you then apply your own risk management and make your own mind up.
        In Scientific or Medical use for eg Dialysis - The water quality is critical and teh cost of ongoing testing and maintenance is off set by the outcomes - Life.
        If ya serious about water quality get a real system otherwise ya fooling your self.
        • #19
          Originally posted by 484C423A370F0 link=1297901145/14#14 date=1298007159
          TG, was the build up in your Expobar lime scale or charcoal or both?Did your Expobar have an in-tank water softener to reduce water hardness further?
          Scale.
          Yes it has an in-tank water softener.
          Next cartridge change Ill filter through paper for a while to see if I find any charcoal like you do.
