My portofino takes forever to get a shot out of . still measuring 9 bar when shot is pouring,,,but it takes forever I need to press button 2 or three times..Any ideas,,,,thanking you.
Portofino pressure problems.
Re: Portofino pressure problems.
Thank you..Originally posted by 715A4D5A4B5352575E3B0 link=1302931010/1#1 date=1302931146With no portafilter in place how much water will come out of the grouphead in how many seconds?
Java "More information please!" phile
Just checked the amount of water is normal.
How finely ground is the coffee youre using? I had this problem the other day with my machine being choked by an extremely fine grind. I needed 3 pump activations to get any coffee in the cup.
Just a thought.
Will give that a go. I have just changed grinders,,but it has been working fine with new grind,,will try that now.thanking you.Originally posted by 0F2C35263A430 link=1302931010/3#3 date=1302933280How finely ground is the coffee youre using? I had this problem the other day with my machine being choked by an extremely fine grind. I needed 3 pump activations to get any coffee in the cup.
Just a thought.
If youre getting normal water delivery and amount with no portafilter in place then as Lovey suggests the next step would be to adjust the grind until you get the proper amount of espresso in the right amount of time.
Java "Adjusting the grind is not a set and forget process." phileToys! I must have new toys!!!
Originally posted by 012A3D2A3B2322272E4B0 link=1302931010/5#5 date=1302934357If youre getting normal water delivery and amount with no portafilter in place then as Lovey suggests the next step would be to adjust the grind until you get the proper amount of espresso in the right amount of time. Smiley
I feel like such a dummy..yep that was the problem..just got a good shot out of itt...
Thankyou one and all
