Help me choose a new Machine!
  • #16
    Re: Help me choose a new Machine!
    Originally posted by 686963706E6B71020 link=1305937858/6#6 date=1306104192
    Did
    Originally posted by 5154413B0 link=1305937858/0#0 date=1305937858
    Budget $3k-ish
    Check out:  http://coffeesnobs.com.au/YaBB.pl?num=1163933911/7#7
    Hmmm,juicy!
    • #17
      Thanks for the plug cj,
      I have added another temptation to the list.... 8-)
      • #18
        coming from someone who owns 3 single group commercial and semi commercial machines.... i would highly recommend going for something dual boiler (eg: expobar minore III). Youve got the price range to choose between dozens of offerings, why not get the best?
        • #19
          Originally posted by 49425A414646230 link=1305937858/13#13 date=1306238161
          Thanks Chris; mine is the Premium Pluss so I figure it is my habbit of leaving the machine on for a couple of hours before I brew that lets it get a tad hot to begin with. A 20 second flush with an empty basket seems to bring it back in line again
          I got my Giotto Premium Plus from Chris and just this morning it was on for 3 hours before I made my coffee and it did not require a cooling flush.
          Well I dont think it did, the water in the group wasnt boiling.....
          • #20
            The ECM Giotto is good and i think in ur price range.....
            • #21
              Hello lu.
              The ECM Giotto was discontinued about 5 years ago.
              Current machines are manufactured by Rocket Espresso: Giotto Premium Plus and Evoluzione
              • #22
                A friend has suggested the Expoibar MinoreIII (4)as have a few of you (thanks again)
                He believes thats all Ill need,is there anything that Im missing out on with this machine?
                But something keeps comming up in the back of my mind.
                That is that I could get a used La Cimbala for much less.
                Well apart from the physical size any one here see any negative reasons for grabbing one of these instead?
                What bothers me is really the power consumption and is it true that they do not run of the normal 240volt plug?
                Thanks in advance for any advice
                • #23
                  I have an Expobar Leva.
                  I decided against the extra bells and whistles of the Minore and that has suited me well for the almost 5 years Ive had it.
                  In all that time its only had normal servicing i.e. keeps on going.
                  Your mention of physical size I take is a personal perception thing as I dont find it overly large.
                  I just rang Di Bartoli to see if I could confirm or deny this for you.
                  Renzo hasnt seen one in the flesh yet but thinks the design will not allow both elements to come on together, hence keeping the current draw under 16 amps.
                  He said it should heat up one boiler first then the other, during initial warm up, from then on it will only need to switch on one element or the other for a short period of time in order to maintain temperature.
                  You can always give him a call yourself to get the explanation in his words instead of mine.
                  Any other sponsors seen one, that can confirm 100%?
                  • #24
                    Thanks for your response,Ill give them a call.
                    But it is the size of the LaCimabali that has me a little concerned being an ex commercial 2 group unit,I love the look but it may seem a bit OTT for home use only.
                    • #25
                      There are a number of us who have 2 groups as home units. They can be quite nice, if you have the space.
                      Java "Still loving his Cimbali!" phile
                      Toys! I must have new toys!!!
                      • #26
                        Hmmmm, still thinking but have put the machine on hold temporarily.
                        Unexpected car expenses can knock the stuffing out of the bank account
                        • #27
                          Woops, double post. :-[
