Faema due smart /A
  • Faema due smart /A
    Hi all
    My machine is overflowng the waste water drain bucket overnight
    There is a centre tube behind the front panel going to the drip tray which is dripping constantly
    Would this be one of the solenoid valves not closing
    Dont know much about them so i am after ideas
    Thanks Glenn
    Re: Faema due smart /A
    is it the expansion / OPV (over pressure valve) leaking and not the solenoid. i might be as easy as giving it a clean as something may be stuck in it making it drip
    pull the top panel off and confirm were the pipe goes / come from
    (turn off the power and unplug first please
      see the attached link
      might be coming from this, expansion valve bottom half of link pics
      can be under the drip tray area and pipe comes back up and into drip / drain. or further under the boiler area.
      not 100% sure of faema layout ...
      http://www.coffeeparts.com/faema/faema-spare-parts-17.html
        Thanks guys
        the water is out of a drain pipe off the right group head
        the pipe comes off the solenoid coil
        Glenn
          3 way valve is leaking - you may be able to fix it by dismantling and cleaning, but will probably need replacing. If youre really lucky a backwash may fix the problem.
            Yeah i thought that might be the case
            I ordered a new one. i will see if i can clean up the other one & keep it for a spare
            Thanks for the help guys
            Glenn
