Hi
I have been going through the rebuild of my Cimbali Junior. Its an older d/1 which was getting close to the end of its "use by".
I thought that I had taken enough photos to use as a reference for the rebuild but I am now against the wall.
The Gicar Controller has 9 connections one of which is marked "G". I assume that the "G" is a ground connection.
My question is .....
Is this a ground connection for the control box only.
The machine is generaly built like battle ship, the wiring throughout is pretty good. Each component is well earthed in the appropriate green and yellow striped cable.
This "G" connection to the controller is a black cable with an "eye tag" at the other end.
Could this connection have been earthed to the main frame of the machine and be common to all other "earth" connections ?
