faema e91 diplomat rebuild
  • #16
    Re: faema e91 diplomat rebuild
    Originally posted by 3B2C2262282A2A232021284F0 link=1321014415/3#3 date=1321498326
    Error code E1 is related to your NTC sensor in the right side of the boiler, you will most probably need to replace this and depending on the model of e91 may need to calibrate the new NTC via the Main-card. Hope this helps
    Could you give me some guidance on the calibration ie where on the card is the calibration screw, I know the pot at the rear left of the board is for controlling the led contrast, but am wary of messing with any other pots without knowing their function. I have a manual of sorts in PDF format but it is not comprehensive enough. If anyone needs it I can forward it on.
    Thanks for the guidance so far, it is a help but has not allowed me to solve the "boiler over pressure E1" problem yet.
    • #17
      Originally posted by 7171637575741A0 link=1321014415/4#4 date=1323944283
      I have also just started a restoration project for a E91 diplomat. I am reconnecting the button panels but theres a connector ( circled in red ) I cant figure out where to plug to. If anyone can shed any light into this the help would be greatly appreciated.
      If you have not found out what this connector relates to already if you can clarify the wire colours which look like yellow brown and black to me, then i will check it out and let you know.
      ............. just checked and it is defo the connector for a flow meter, as this appears to be a 2 group it is probably a standard loom that is used
