Giotto Evoluzione brew head gauge
  • Giotto Evoluzione brew head gauge
    Hi there
    Just wondering should the brew head gauge go back to zero after extraction of the coffee or should it stay around three bar like mine does. That is when the machine is on and idle it stays on three bar.
    Re: Giotto Evoluzione brew head gauge
    Originally posted by 41626A6A6C0D0 link=1321247377/0#0 date=1321247377
    Hi there
    You have it plumbed in, yes?
    If so, the reading on the gauge is measuring the line pressure into the unit, ie. all good.
      Originally posted by 57767D7D7A60130 link=1321247377/1#1 date=1321248493
      You have it plumbed in, yes?If so, the reading on the gauge is measuring the line pressure into the unit, ie. all good.
      Hi Dennis, no its not plumbed in.
        Oh.
        If youve had it a while, it might need to be descaled. The tubes to the gauges are quite narrow in diameter and can easily become clogged with scale.
          No only a few days old.
            May be just a faulty gauge.
              An E-61 can continue to show pressure in the group after an extraction even if it is not plumbed. Nothing to be concerned over. If you lift the lever just past the point of first resistance you will see the gauge drop as the brew valve opens.
                Thanks for that Randy.
                  My Evoluzione does the same thing as yours, so it must surely be normal...
