I just finished the refurb on my new acquisition. A Bezerra BZ 35e. This is a small commercial machine with a 2 l boiler, so is very suited to home use. Its also not too much larger than the BZ 99 and will fit in the kitchen nicely. My machine has a fluid-o-tech vibe pump, so doesnt need to be plumbed in, but can be if desired. It doesnt have an internal tank, so Im using an external water container.
I only had the machine for 2 days when it decided to stop. Well it actually ran, but not well enough to make coffee. I thought it was the pump dying on me. However, after pulling it apart, I found the true culprit.... lime scale! So 3 containers of citric acid later as well as a bottle of CLR (sulfamic acid plus detergent) and some phosphoric acid and shes clean and fresh like a new baby. Scale aside, this machine really needed this, as the previous owner had run the machine with the water level below the element, so the boiler had a smell that was ..... really bad. So everything metal got an acid bath and pipes scrubbed with pipe cleaners and test-tube brushes.
Heres the end result:
Heres the cute little boiler and HX after their bath:
And heres what was left inside (room for a tennis court
The machine still hasnt graduated to the kitchen yet. These Bezerra machines are fabulous to work on. Very easy to access and remove parts. Every part is available as a replacement and the build quality is very high. The only remaining problem is the 4 hole steam tip. Im looking for a 2 hole ECM or Diadema tip to replace this monster tip that heats milk for a single cappuccino in about 8 secs (no room for error, and plenty of errors on my part).
