Bad news is the guy went through the whole storage shed and there was no motor/pump so ill be hunting one in the next week or 2 but in the meanwhile here are the Before pics i promised the whole thing looks good the end plate area of the boiler has a bit of corrosion but ill sort it out, these pic are just with the panels off ill start pulling here apart tomorro hopefully ;D
this sticker show that at one stage it has been service unlike most commercial machines :P
That little box down the bottom is where all the 3-way valves empty and the drip tray
you can see the corrosion nicly here
you can see the boiler has an endcap which will make for easy cleaning and ill replace all those seals and gaskets
that small pipe there is the reducer that robusto was talking about i think
More to come shortly
but am sure you will do a far better job - good luck with it all!
