Anybody ever insulated a boiler?
  • #61
    Re: Anybody ever insulated a boiler?
    As part of my boiler insulation, I made this copper tube coil that fits tight around the boiler. I use it to preheat the boiler feed water. This way the pleasure/
    Temperature don’t drop when the boiler get filled. I then insulated the boiler and tube with braided fibreglass tape, same stuff they put around car exhaust pipes, and then covered the fibre glass tape with a self adhesive  aluminium tape, as used on air condition ducting.
    It all works very well
    • #62
      Some quick and random thoughts.
      By introducing such a coil, you are doing a "heat exchange" from the boiler, to preheat the cool water in the coil before it goes into the boiler. Youve just given your boiler system / electric element more work to do ie more water to heat, and therefore slowed up the heating process which means the element stays on for longer.....no?
      So theoretically, you have just gone part of the way to undoing the effect of trying to make your boiler more efficient by insulating it in the first place....?
      Also when insulating, you make the whole system run hotter by keeping the heat in. Use less power yes, but now you have to contend with the effect of over run of temperature on the brew water. So then you have to cool the machine down by making more mods......(I know this as Ive done it before)?
      Intorducing the pre heat / extra heat exchanger has just probably balanced it all out a bit and made the overall nett effect "softer"......?
      Seems like a lot of effort for not much real gain, except for the personal value in the enjoyment and satisfaction of doing the project ......
      Just my opinion.
      • #63
        Originally posted by 023621372C1B072B22222121440 link=1183704092/61#61 date=1337152522
        I dont understand how you would make the machine run hotter without changing the pressurestat setting. Wouldnt it just reach the desired temp/pressure quicker and then just turn off?
        • #64
          Originally posted by 7C485F49526579555C5C5F5F3A0 link=1183704092/61#61 date=1337152522
          I agree with that.
          ..but... (yeah most of the time there is a "but" after "I agree")...
          ...maybe the pre-heat wont save (much) power but might make for more stable boiler temperatures with less fluctuation, more so during the auto fill cycle.
          I guess thats what you meant by the nett effect being softer?
          Pre-heat should flatten out the temperature graph.
          Excellent looking job too MJX.
          Silver solder (not tin/lead) I hope?
          • #65
            [QUOTE=4B646E730A0 link=1183704092/63#63 date=1337157804]
            I guess thats what you meant by the nett effect being softer?.........
            Yes thats what I meant.
            The machine will recover more quickly and overshoot more after the element switches off, there is a build up of heat in the system that cant escape like it used to due to the insulation.  More likelihood of scalding your coffee, much longer cooling flushes required, much quicker recovery and overshoot between making coffees requiring more and longer cooling flushes. That is my experience with the machines Ive done, and I guess that means I did a good job on the insulation......
            The machines are thermically designed the way they are, and when you change that there are consequences to deal with in the set up. Action / Reaction.
            • #66
              I insulated my Giotto Prem plus last week.
              I didnt want to pull the boiler and assembly apart so I used insul-brite in 2 and 4 layers (depending on space) with cutouts where required. I am using zip-ties to secure it.
              2 benefits:
              a. longer off time on the boiler in cycles,
              b. quieter and lower tone to the noise.
              As far as noise goes either I put it back together better than it was before w.r.t panels etc, the insulation is absorbing some of the noise, or the insulation is now between parts that were vibrating previously. Perhps all of these points.
              reducing the direct heat exposure to plastic components and electrical components will benefit them in the long run.
              Is the "long run" a time relevant for us as owners .... who knows.
              I did it because I could ;D
              Due to the surfeit of piping, the group head etc I cannot use the heat of the cabinet as a test by hand to determine how effective the insulation has been.
              It will help but I can only assume that a thin fibre like insul-brite will reach energy saturation fairly quickly and begin to conduct heat. Radiant energy will be reflected back by the reflective barrier.
              • #67
                [QUOTE=4C786F79625549656C6C6F6F0A0 link=1183704092/64#64 date=1337159184]
                Sure, a control system will overshoot if the rate of change in the system is greater.
                In this context I would expect different machines will suffer more or less depending on the ratio of element to boiler, amount of other surface area to allow heat escape (which will affect the total change to the system in altering the boiler) and probably many other factors.
                The feedback aspect of the loop here is mechanical yes? so you cant alter the arrangement without messing up other factors that you dont wish to. Probably not an easy, perfect solution for the home user...
                Personally I think the best way to do it is DIY insulation that is reasonably effective in achieving our goals  yet doesnt swing things so far that the coffee is worse in the cup  :
