Rancilio S10
  • #16
    Re: Rancilio S10
    I ended up removing the whole group head, drilled through the gasket with a pilot and then 6mm drill. This allowed me to prise up the gasket and then clean the mating surface with a couple of nice sharp screwdrivers. I then cleaned it all up using some fine steel wool. Looking good now and ready for new gaskets. Incidently there was no group spacer under the rubber gasket!?
    Thanks for all your help everyone. CS is a great place for great help.
    • #17
      Re: Rancilio S10
      Here a some pictures of my new (well, very well used) machine.
      • #18
        Re: Rancilio S10
        can someone please explain this device to me?  On the left is where the water enters from the pump.  The two copper pipes at the top go to the bottom of the boiler (the return from the groups) and the one tube on the right goes to the inlet valve.  What does the needle valve tap do?  Is there a one way valve here somewhere?
        • #19
          Re: Rancilio S10
          My guess is a manual fill for the boiler...
          • #20
            Re: Rancilio S10
            Hi, does anyone have a manual or know where I could get one for this model of Rancilio (S10/CD) please? Thanks!
            • #21
              Re: Rancilio S10
              Have you try Rancilio Italy website;
              http://rancilio.it/rancilio/download_page.jsp?flag=1&id_cat=12&id_language=3
              if it not here send it a email to them.
              Regards
              Renzo
