Basic info on Rancilio 2 group please
  • #16
    Re: Basic info on Rancilio 2 group please
    hi again
    the non return valve is fitted before the pressure limiter valve.
    the white housinig is a water filter housing, it is not a water softener unit.
    if you undo the bottom of the housing it will have a removable internal filter.
    the standard filter size is 10 inch.
    depending on the water quality in your area depends on waht filter cartridge you use. basic dirt filters are available from most hardware, but it is best to use a cartridge with an inbuilt scale inhibitor, available from most coffee repairers
    in the pict you didnt show what you thought was a foot switch
    not required when hooked to mains water supply
    graham
