Single Group Commerical
  • Single Group Commerical
    Just starting to think about upgrading to a second hand single group commerical machine. There seem to be a number of machine brands that are in the market place and am interested in hearing peoples opinions on the pros and cons of a few of the machines.
    The ones that seem most popular in the home market are the Bezerra and the Boema. Have also seen San Marco but not too many other options. Im sure that there are heaps but I havent seen too many.
    Any opinions or advice on what to start to look for? Im more than happy to get an older machine as a project but confused on what to look for. I have no problems plumbing in the machine.
    thanks in advance
    Mike
    Re: Single Group Commerical
    Dont forget the La Cimbali Junior/Faema E98 S1
      The Carimali seems to be fairly common on this board and looks like a good machine for secondhand money. I recall reading somewhere that they were standard issue as one of the fast food joints for a while, so do come up second hand.
      See http://coffeesnobs.com.au/YaBB.pl?num=1175840909 for a piccy.
        There seems to be a myth that commercial machines are somehow better than prosumer machines and that second-hand commercial machines represent great value. The fact is that with both prosumer machines and commercial machines there are some that are totally crap, some that are OK and some that are absolutely brilliant.
        From what I can tell, the only reliable way to tell whether or not a machine will produce decent coffee is to actually make coffee on it. Even then, though, your information will only be as good as your frame of reference. The frame of reference problem also pollutes most of the information that you get online - very few people actually get a chance to spend significant time using different machines and a lot of people seem to improve their barista skills and palates as a result of upgrading to a new machine, so its pretty difficult to work out how to weigh one persons totally happy and satisfied opinion against anothers. Then there are, of course, differences in each individual peoples tastes - for example, there are a number of machines that keep on cropping up that I wouldnt touch with a ten foot pole and I know some people with fantastic palates who dont like the machines that I like.
        You can take the above as optimistically or as pessimistically as you like. The pessimist would just say that its exceptionally difficult to pick out the machine that you would truly want to have if you had all of the information that you would like at your disposal. The optimist would be happy with whatever he or she had. The pragmatist would just try out as many different options as he or she could before going with what seemed best.
        With second-hand commercial machines, the one thing that you can be pretty sure of is that you will end up with a plumbed-in machine with a rotary pump. Everything else can vary immensely. I suppose that the best advice would first be to realise that its very much a case of caveat emptor and plan on doing a lot of repair work, which can be costly and time consuming. The next best piece of advice would be to check the availability of spare parts and knowledge for any machine that you are looking at buying.
        Best of luck!
        Luca
          Best of luck!
          Luca
          Hah! You can say that again! I have a machine in a quite a number of parts, ready to be reassembled. I just have to order some gaskets, find some new fasteners and find the time to put it back together. :
            Best of luck!
            Luca
            I can sympathise DS. :
              I know that Boemas are rated amongst the worst commercial machines out there, but their biggest problem according to most is build quality. Three questions:
              1) Is build quality the main problem with Boemas (and other less desirable commercial brands)?
              2) Assuming you could get one in reasonable nick, would build quality be a problem in a home setting (given that it relates most directly to longevity)?
              3) How are these (and similar low-end commercial) machines in terms of the "in the cup" factors like temp and pressure stability?
              Stuart.
                Thanks Luca, I really appreciate your advice and guess that one of the more specific questions that come from your advice would be
                Which machines have better support / spares / general advice than others?
                For example I have heard that Boema is excellent at supporting even very old machines and are very helpful to deal with.
                Im not too concerned about spending a fair bit of time on repair work and would enjoy the challange. I think that one reason for thinking about the commerical machines over the prosumer equivalent is that the commerical machines seem easier to get a hold of. I havent seen many prosumer machines that people are selling off but there seem to be quite a few single group commericals that are changing hands.
                After all of this there is still the sales pitch to my wife prior to any cash being spent....
                Mike
                  Like everything in life, its all relative.
                  There are great gains to be had from even modest changes in the beginning. After that, I suspect its increasingly micrometrical!
                    Can I just add a subjective view - and without the benefit of having other commercials to work with such as would be Lucas experience.
                    My 1995 FAMEA Due is easy to get parts for and easy to work on and fit. I am a shiny pants but found changing the pressure-stat diaphragm, steam valve seals, and group head seals, pulling apart the pump, adjusting the pump pressure, cleaning the pump bypass valve, all relatively easy. The thing I love about the this machine is the heavy duty build of everything - it will outlast me with care.
                    I also love the espresso quality - and consistency that comes with big hunks of brass. I would have thought that a commercial machine, irrespective of type would also blow the doors of prosumers for quick and quality espressos and milk stretching when a party is on. I love being able to easily keep up when the house has 15 -20 adults in it all putting in orders!
                    The basic maintenance parts are not expensive at all from what I have found but that also may be dependant to an extent on the manufacturer and how common their machines are.
                      Thanks to all for your advice. Im very interested in getting a machine but now need to determine the best place to get one. Ive started to look on evil bay and am surprised at how little some of the machines go for... but have no way of knowing what condition they are really in. Also started to have a look at some of the commerical auctions but have the same issue with those really.
                      Any other ideas about where to pick one up from? Any one got an old machine sitting in the shed that I can get for a low cost ???? (worth an ask)
                        I got mine out of the Commercial equipment section in our local Quokka = Trading Post
                        Happy hunting.
                          Start with the Yellow Pages - search for commercial coffee or kitchen supplies or whatever. You can even get hits with "used commercial coffee" I did a searh on faema and there was one place in Sydney listed that specialisied in used commercial equipment but Im not going to mention a non-sponsor.
                          A lot of these places dont have websites so it sounds like a bit more than letting your fingers do the walking. Another possibility is 2nd hand joints but it sounds like it might be a lottery finding one that has an old commercial espresso machine gathering dust. What about auction joints that specialise in solvency sales e.g ex-restaurant, cafe equipment?
                          I wonder why you would specifically want an ex-commercial machine. I think Lucas advice was pretty good.
                            Has anyone suggested silver chef as they have ex lease/rental units for sale with warrantee?
                              They have now. No single groups among the used stuff.
                              mod edit- commercial link removed
                              EDIT: Sorry about that chief :-[
