No!!! Tell us about the coffee machine!!! :-?
Another Extreme Machine... :)
Re: Another Extreme Machine...
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;DOriginally posted by 6169717B66020 link=1233884536/21#21 date=1241606503No!!! Tell us about the coffee machine!!! :-?
$570. Even came with a grinder!
Sorry if any other Coffee Snobs were after it!
x2. People keep finding things on the side of the road or picking things up for 1x10^-300 th of the original priceOriginally posted by 656D757F62060 link=1241606504/2#2 date=1241607856Where do you guys find these things????
I found it on tradingpus.
I have been looking there and on evilbay for the last 6 months for anything that was a bargin. Been looking on the side of the road too, but no luck!
There maybe problems, dont know. Looks in really, really good condition. The brew groups are filthy.
Being an electronic technician I know any problems are only time and money for parts. Probably a better deal to me than others.
Dunno about that bjeck: there was a story about a gynaecologist who thought he might try a career change and did a mechanics course at TAFE. For the final exam, they were required to re-assemble an engine.Originally posted by 2B232C2A22787D490 link=1241606504/5#5 date=1241654270My biomedical (biomechanical) engineering doesnt give me any real-world skills dammit!
The gynaecologist was surprised that not only had he passed but he received a Distinction.
He approached the trainer and pointed out that he only managed to put the engine together like the others. "Yes," the trainer said "but we gave you extra credit for doing it through the exhaust pipe"
Dont know if this was a true story or not
</OT>
Lol that story would probably work better though if it was a proctologist, not a gynoOriginally posted by 666C796E6E617573000 link=1241606504/6#6 date=1241656186Dunno about that bjeck: there was a story about a gynaecologist who thought he might try a career change and did a mechanics course at TAFE. For the final exam, they were required to re-assemble an engine.Originally posted by 2B232C2A22787D490 link=1241606504/5#5 date=1241654270My biomedical (biomechanical) engineering doesnt give me any real-world skills dammit!
</OT>
Update, its alive!
I was dying to plug it in. Asked the sparky at work. He said no problem, if you have the standard wiring, 2.5mm, just change the outlet and up the fuse. Yes I know, illegal if you arent qualified.
Bought the outlet. Got home. Moved the couch out. Looked at the outlet, its white! All the rest in the house are cream. Its already a 15amp. ;D
Powered up ok. Boiler was set at 1.3. Pump ran fine. Set at 8 bar.
Only one of the groups worked. After a while, no brew pressure at all. >
Next day fault found the non working group to some where between the start of the three way and the head. The brew pressure is back!?! Took the head off. FILTHY! At that point I decided to take other head off and clean it as well. Found the blockage. The "group jet" (Coffee Parts part number 703504) inlet was blocked with corrosion.
The boiler sight glass top gasket was also blocked. Now fixed.
Put it all back together and put some descale through. Came out pretty clean.
Now the sight glass works I could see that the boiler fills but only to a little less than 2/3.
The machine seemed to run too hot. I backed the pressurestat back down. Tried it a 1. Still the same. Tried at 0.8. A bit better but the steam isnt as good. Other strange things. The pressurestat sometimes sat in between states, arcing away. Another time it stayed on reaching 1.5 before I switched off.
I left the machine on for hours. When I tried a blank shot no brew pressure again. Pump just runs, no brew pressure, no water flow.
I released the pressure off through the steam wands. Switched back on. Brew pressure back, water flow back!
Me suspects the boiler isnt full enough. The boiler then becomes full off steam. Pump is just pushing steam around, maybe? Might explain the other pressurestat problems.
I take the earthing probe off untill the boiler is full on the sight glass.
The shots ran cooler. Bumped the pressurestat to 1 bar. Seems to be running at the right temp. Left on for four hours. Still have brew pressure.
Pressurestat now seems to be working fine. Other things "seem" right, like the first blank shot when the machine has been idle for a while runs too hot. Before it didnt make a difference.
See what tomorrow brings.
The shots are already noticeably better than from the Silvia.
Makes me one happy boy!
If you have questions feel free to ask me. I did a resto on a single group Brugnetti a while ago.
My machine was a 1994 machine...group head was nasty! Unbolted it, descaled the whole thing, had a lot of fun trying to get the showerscreen off. Once off, scrubbed the group head like crazy to get rid of the nasty old coffee and chiseled out the gasket.
Have fun
Thanks David!Originally posted by 1133352E292335460 link=1241606504/10#10 date=1241964293If you have questions feel free to ask me. I did a resto on a single group Brugnetti a while ago.
Have fun
I am having fun!
I thought that my Brugnetti would be slowly fixed up and stay in the garage until I re arranged the kitchen. Was going to continue to use my Silvia.
The Silvia hasnt been switched on since!
One of my shower screens come off ok. The other had to be pried off.
The water dispersers were horrible. As I managed to screw them off chunks of dried up coffee grounds came off in strips. YUK!
I didnt have to chisel out the gasket but did have to use the screw method.
Questions? I have many!
Please excuse any stupid/meaningless questions; I am new to this coffee snob thing. I only joined last October. Started home roasting mid Oct. Ive had a Silvia (my first machine) for about 18months. Just PIDed it mid Jan. Probably learn to clean it properly at that time.
Now I have this beast in the kitchen. One short, very steep learning curve!
The machine seems to run hot. Left to idle the first blank shot will spit. All blank shots are bubbly. This is where the pressurestat is set to 1 bar. Does this seem normal?
Probably need to scace it. Even then, if it is running hot how do I adjust it? I don’t really want to drop below 1 bar. At 0.8 the steam seems wet. Put heat sinks on the brew pipes? Just a thought!
Still, the shots are better than from the Silvia.
What is the BFC steam arm and tip? Mistral tip? What difference does it make to steaming milk? Where do I get one?
Currently both tips are four hole. Would changing to a two hole help with smaller amounts of milk?
This is one area where the Brugnetti is in another world. Steaming for one latte on the Silvia would take twenty or more seconds. You can do milk for two lattes but the Silvia does run out of puff. Normally I would steam for one, prime the boiler, wait for it to get back to temp and go again.
Brugnetti? Three seconds for steaming milk for one latte. Three seconds.
Milk for two lattes seems to work better. This seems to take about 6-8 seconds. Very quick for my very, very, small amount of experience.
Can the auto volume be set?
Im not that concerned, I hit the double button, wait till I want to stop and hit the button again.
Any suggestions and answers are very welcome!
Oh, Its a 99 "C" model. 8 litre boiler. The heater element is 2800 Watts.
Thanks.
Yes, depending on how long the machine has been left, I flush my machine for a good 8 seconds until all superheated water comes out of the heat exchanger.Originally posted by 2C2F3D3D392F374E0 link=1241606504/11#11 date=1242004642The machine seems to run hot. Left to idle the first blank shot will spit. All blank shots are bubbly. This is where the pressurestat is set to 1 bar. Does this seem normal?
I also have my machine set at 1 bar. The results have been good when you nail them.
I changed to the BFC steam tip and arm....which is a vast improvement on the standard Brugnetti arm and tip. It did need a bit of modifying to get the arm on (had to buy a spring from Bunnings) and bending the arm out a bit to give it full range of motion.Originally posted by 2C2F3D3D392F374E0 link=1241606504/11#11 date=1242004642What is the BFC steam arm and tip? Mistral tip? What difference does it make to steaming milk? Where do I get one?
Brugnetti? Three seconds for steaming milk for one latte. Three seconds. Shocked
The BFC tip will make things a little slower....but not by much! Its the steam tip used at World Barista Championships. Its a 4 hole tip with something like a 1.2 mm holes. Even I was blown away by how much steam pressure the thing had at 1 bar, blew the La Marzocco dual boilers right out the water.
I wouldnt change to a 2 hole tip, in time you will learn to master the 3 second milk steaming and get beautiful silky milk every time. For now though, I would just block up one or 2 of the existing holes with a toothpick.
re: mistral tip. Its probably the best steaming tip Ive used, easy to keep clean and dead easy to make great milk.
Yes it can, via a very old school key switch method. From the picture, I cant see the key switch though. I had to replace the switch with a new one because the machine didnt come with a key. Once in, its as simple as flicking the key in to the 2nd pole which activates programming mode, then running the groups for as long as needed. I actually never use programmed key pads, I will always use the manual brew button regardless of what machine it is. This button on the keypad is right-most button with the Brugnetti logo on it (Im sure you already figured that out!)Originally posted by 2C2F3D3D392F374E0 link=1241606504/11#11 date=1242004642Can the auto volume be set?
wow, my single group is over 2000 W and 7 L boiler.Originally posted by 2C2F3D3D392F374E0 link=1241606504/11#11 date=1242004642Oh, Its a 99 "C" model. 8 litre boiler. The heater element is 2800 Watts.
Good luck
Thanks again David,
Now I want one! So where so I get this BFC arm and tip?
Coffee Parts? Is the the arm for the Nuova?
http://www.coffeeparts.com/simonelli/703474.htm
Yep I figured out the manual button! But the four other buttons have pre infusion, the manual doesnt. Do know what that means in the cup. I am sure getting the brew temp right is more important.
Key? Huh? Ill have another look. Cant remember seeing anything.
Yep, I thought the boiler would be bigger. My friends Faema takes about 40-50 mins to heat up. This thing takes about 15. Although to heat all the brew group and handles takes 40-50. It recovers quick. The pressurestat kicks in and you can see the needle move fast.
