New toy (GS/3)
  • kaloolabmeb
    Re: New toy (GS/3)
    Hows it going now that youve had them for about 6 months? Ive been doing some research, and on an American website I read that there was some problems with a "blocked gicleur".
    Still happy and think it was worth it? Any problems?
  • Gavin1
    Re: New toy (GS/3)
    Originally posted by 54616C6B5F436F66666565000 link=1246097816/50#50 date=1249212506
    Originally posted by 1234233C3B64550 link=1246097816/49#49 date=1249199345
    Have you been mucking around much with pre-infusion chris?
    I have played a little Gavin...
    I like that you can use mains to ramp it as long as you like- and in fact pour a whole shot without the pump if you like. I have found that an early backoff seems to work well...
    Come for a play someday
    Sounds awesome. Would love to be able to do that on my GS/3. Ill just make a paddle out of cardboard and pretend
    I might just take you up on that offer!
  • roknee
    Re: New toy (GS/3)
    hey chris
    sweet setup mate
    im sure youre loving the playability of your LM.
    you can plan espresso God with that paddle yknow
    Re: New toy (GS/3)
  • Gavin1
    Re: New toy (GS/3)
    A paddled gs/3 needs to be plumbed to be able to make full use of the manual pre-infusion anyway so although id prefer a paddle i wouldnt be able to use it.
    Ill just buy a slayer when I win the powerball and move into my new home...
    Re: New toy (GS/3)
    Originally posted by 7D65606075644F7D717E2627100 link=1246097816/44#44 date=1249194568
    How does the footprint compare to other domestics? Im surprised at how big the K10 looks next to it. From that pic it looks a much more reasonable size then a Synesso for home use.
    Howdy MM,
    Details including the footprint are at http://www.talkcoffee.com.au/downloads/coffee-machines/lamarzocco-gs3-flyer.pdf
    Originally posted by 54757E7E7963100 link=1246097816/46#46 date=1249195012
    re you going to drill more holes in the counter to tidy up those leads?
    Erm, nope Den....
    I need to do a little work underneath to secure the lines out of the way...Like the mechanics car, Im gonna get a round tuit ;-)
  • acoggins
    Re: New toy (GS/3)
    Originally posted by 797B777F7F71766B180 link=1246097816/38#38 date=1247663250
    Pics or it didnt happenSmiley
    OK, so it did happen
    Originally posted by 5F796E717629180 link=1246097816/43#43 date=1249194523
    mmmm........paddle
    IIRC Gavin, you had a choice....second thoughts?
    My my, thats a nice machine. Wonder if I have enough equity in this house yet....
  • Dennis
    Re: New toy (GS/3)
    Nice pics Chris. The low lines of the GS3 make that paddle look even more imposing!
    Are you going to drill more holes in the counter to tidy up those leads? ;D
  • Koffee_Kosmo
    Re: New toy (GS/3)
    Originally posted by 4951545441507B49454A1213240 link=1246097816/44#44 date=1249194568
    My Galatea can fit 3 cups across and the GS3 has 4
    So from the pictures its probably only 10 cm wider
  • muppet_man67
    Re: New toy (GS/3)
  • Gavin1
    Re: New toy (GS/3)
    mmmm........paddle
    Re: New toy (GS/3)
    I guess its time for some happy snaps of mine....
    Great pours and Im happy with the way its running.
    Ill let the pix talk  8-)
  • Gavin1
    Re: New toy (GS/3)
    Originally posted by 383F2D2F2D262D3A480 link=1246097816/40#40 date=1247806902
    HI  Shaun
    i think my gs3 is set at 94 .....  what temp are you usung to get the cocoa earthy flavours? 95 .....  or higher ?
    regards paul
    Do take note of the offset temperature. If your coffee boiler is set to say 95degrees and your offset is -2 then your brew temperature will be approximately 93. Only way to find out is with a scace and your machine should be factory calibrated when you got it.
    Changing the temperature doesnt exactly ALTER the characteristics of the bean. It wont give you a floral and bright brew at 93 degrees and a full bodied earthy cocoa brew at 95 all from a Yirg.
    It just enables you to highlight or amplify the characteristics of the SO/blend you are brewing.
  • pwegener
    Re: New toy (GS/3)
    HI Shaun
    regards paul
  • shaun3357
    Re: New toy (GS/3)
    "Im seriously blown away by the programmability of this machine. Slightly higher temperatures and the cocoa, earthiness and body is amplified. Lower temperature for more fruit, acid and high notes."
    Thats what I meant to say!  Thanks for putting it into words, Gavin.
    shaun
