Hello CS
Need some advice, and this is the best place to be!
Currently in the process of starting up Mobile Coffee, just something small for now, just on the weekends to keep my passioon fueled (because working 5days a week isnt enough).
The questions I have are; My Set up is Expobar Medacrem 2 Group 15Amp Machine and Diamond Grinder. I have the machine setup with a Bayonet Filter and a one-way-valve, I started it up on the weekend, and felt I may need another pump to keep up with demand if I do get under the pump, I found the machine pulled good shots and steamed well but I think the Expobars water pump is under too much stress, having to suck the water up through valve, the filter and the braided hoses, would I be correct in saying this? Could anyone recommend a solution (remembering its mobile).
Another problem I found, when I turned the machine on the left group electronic pad was flashing at me, I turned the machine off and on again and it seemed to go away. When I was pressing the 30ml shot button it wasnt pouring the same, some times it would pour 15ml other times it was pouring 45ml (using the same grind which was perfect on the other group) so I suggest an electrical fault, but does this mean something needs replacing, I dunno, lol.
Anywho thats all the information I will pump from you guys....for now. Thankyou in advance for your help and advice
