Re: Grimac "Ten" Series 2 Group Compact
1: Looks like I was lucky again...
http://coffeesnobs.com.au/YaBB.pl?num=1267349925/9#9 ;D
2: See reply http://coffeesnobs.com.au/YaBB.pl?num=1267349925/4#4 and re visit my other posts in this topic as to managing the Electrical issues.
3: I recon they also bent the sensor as some one has assumed that if it was touching the element that was causing the system to blow.. Some time after that, it blew out and then they disconnected the element.
4: Not sure where you can get a new element... Other than contacting the manufacturer directly or contacting a company in your area / location that do custom elements..
They may be able to use the brass fitting and that should reduce costs...
NOTE: Get ya wiring installed and set up for 20A. That way be it 10A, 15A or 20A now or in the future... It is done and your safe.
If ya decide to keep going with one / two elements.. I would still get the wiring done...
A some stage the element will fail and then you will be having to get a new one..
ALSO; Please get the un used element connectors correctly terminated by your electrician; so that the other element can be connected at some stage in the future. Just do not use standard electrical tape as it is not suited for this.
http://coffeesnobs.com.au/YaBB.pl?num=1267349925/9#9 ;D2: See reply http://coffeesnobs.com.au/YaBB.pl?num=1267349925/4#4 and re visit my other posts in this topic as to managing the Electrical issues.
Originally posted by 4F445E455F58435F1D1C2C0 link=1267349925/14#14 date=1267967029
missing on purchase.
