I am starting this thread to see if other CS home users are out & about that own or use a Bezzera BZ40
Preparation needed to install one of these puppies for home use are
1) Have a dedicated 15 amp power line & plug installed by a certified electrician to handle the 2 X 1450W elements
* That line was installed today
2) Fit an appropriate water filter for plumbed in coffee machines
* I have installed the commercial Everpure filter system with quick change head
3) Also need to feed & connect a drain line
I will keep you all posted when the new machine arrives home
Now some specifications
Mine has black sides
* Volumetric 1 group commercial espresso coffee machine.
* Plumbed-in model.
* Combination of 3.4 Litre Copper Boiler with 2 x 1450w elements and a commercial pressure switch
* Heat exchange system
* Built-in robust commercial rotating pump.
* A double reading gauge for steam pressure and pump pressure.
* Chromed cast and commercially designed Group head (not e61) and commercial group handles
* Plumbed-in model.
