What would be the minimum pipe size for plumb in rotary?
Its for the Brugnetti 5L boiler HX roto-flow commercial machine i have
pump is external, it will more than likely end up under the sink and a copper line run to the machine
whats the min i could go on the pump to machine
water tap to pump can be 15mm no problem undersink
I have moved into the "new" house and am fitting in the machine, issue is i have stone benches in kitchen and reluctant at this stage to drill a hole.....
considering a plug an play for a bit till i sort out a "hole" and looking at john guest water filter / beer line set up or 1/4 inch copper etc.
might sneak through the wall around the benchtop.....
your help is much appreciated
Maheel
Maheel
