Carimali Relay
  • Carimali Relay
    Hi Guys, I have a relay in my machine a S. ECO E2 that needs replacing, it is a FANAL DSL-10SP4 I cant find this anywhere however I have found a chart which states that a FANAL DSL-10 can be replaced with a Iskra K07M-10  (not sure what the SP4 means)
    Can anyone advise if this is a suitable replacement,  is there anything else I need to look at which might have caused this to fail in the first place? I did notice while stripping the machine down for a descale that one terminal on the heating element was a little loose.
    Also any pointers on how to remove the heating element, seem very tight are they just a screw out RH thead.
    Thanks,
    Jamie
    Re: Carimali Relay
    I have found an alternative an ABB B64000 it is installed and working for anyone else having this problem.
