Imagine for a moment that cost was not important....
  • lmclaren
    Re: Imagine for a moment that cost was not important....
    Still looking for a machine to start with, I want a HX as the output from the HX will feed the brew boiler. Maybe a 2 or 3 group as I will want a lot of room while prototyping.
    My friend assures me that making the boiler is simple ( he will be doing the welding etc) I was hoping to start out with something running so that I dont have to buy a heap of bits just to get going.
    The first machine will be the prototype and I will make custom steam boiler after.
    Looking for a nice gear pump atm, I have some ideas re saturated pump with the motor outside.
    Not much one ebay etc atm, but I have collected a lot of info.
    regards
    Lee
  • Ronin
    Hows the searching going Lee?
  • lmclaren
    Yes, group solenoid. I have found an exploded diag, just need to see what parts are avail.
    The gear pump sounds like a good idea, havent found a price yet ...
  • coffee_machinist
    Lee, when you say
    the flow and control valve on top of the group to limit the temperature fluctuations
    do you mean the group solenoid and flowmeter?
    If so these are located directly on the group cap in GB5/FB80 models, and outboard on copper lines on Lineas. Whether this has any effect on temperature stability is highly unlikely as the water path still travels back through the group before hitting the puck. More of a reason of economics, as the flat Linea group caps are much less complicated to manufacture.
  • lmclaren
    Thanks, I will avoid EP.
    I may make the grouphead and boiler, that way I can make some changes, hopefully the bits that bolt on will only add upto around $400, I seen a group quoted at around $700.
  • Ronin
    Sorry Lee, I cant tell you. Even through out the GS models the internals of the group changed. Not a great deal, but I thought they were the same until recently photos came my way.
    FYI Im still waiting on some parts from espresso parts that were ordered and paid for 7 myths ago. Not happy about that.
  • lmclaren
    Thanks again Ronin,
    signing up for a catalog
    Do you know off hand the model of the Marzocco that had the flow and control valve on top of the group to limit the temperature fluctuations? There are a lot of models out there and I am still finding my way.
    best regards
    Lee
  • Ronin
    Originally posted by 44454B44495A4D46280 link=1329112945/15#15 date=1329292321
    Originally posted by 3328222A1E232E2F25410 link=1329112945/13#13 date=1329215978
    Reply #13 - Yesterday at 9:39pm Mark & Quote Quote
    Espresso Parts in the states list all the LM group parts (group casting: MZ_202) but it will cost you a small fortune
    Rick, Do you think that is the whole group head or just the body? $400 isnt scaring me (a lot) . I would prefer to pick up an old machine to start with but where?
    Do you have a link for the  EU site Ronin?
    Might be deleted as not a site sponsor, but
    ricambigardosi.com
    Also keep in mind that if you are getting an earlier Marzocco with the groups bolted to the boiler, try and get one with the end plates on the boiler, not welded.
    The welded ones have fewer problems with leaking, but have a good read of the espresso restorations website re the GS2 rebuild Paul Pratt did about reassembling the group retaining nuts. http://www.espresso-restorations.com/GS2-3-2.html
  • lmclaren
    thanks Rick
    Doing a lot of reading re the Marzoccos.
  • coffee_machinist
    Youll need a few more bits to make up a complete group, namely the diffuser disc, group cap and bayonet collar, o-rings, washers and internal plumbing. Then youd have to decide where youre putting the brew solenoid - different LM models have it either outboard or integral to the group cap. A complete groups worth of parts will cost rather a lot.
    If you are looking around for a donor machine, keep in mind that the groups of later la marzoccos are TIGd straight to the boiler.
  • lmclaren
    Being in Tas makes shipping expensive but for the right machine I suspect I would fly over.
    best regards
    Lee
  • Ronin
    Espresso parts are expensive. Freight is a killer from USA. I recently was pointed to a EU site which looks promising.
    You might be better off looking for an old but complete machine to get parts from. Could save money, give you ideas and still able to customize it.
    Mine will be almost standard except for PID controls. Im even keeping the manual water inlet valve. I want to be more involved in the process manually, not electronically. Maybe a lever next ;D
  • coffee_machinist
  • lmclaren
    I am jealous as hell, beautiful machine....
    I have designed and build a high tech roaster, detailed on another site, can post a link if ok?
    Ready for a new challenge, anyone know where I can buy a Marzocco group head?
  • Ronin
    Originally posted by 5F5E505F5241565D330 link=1329112945/9#9 date=1329206478
    Ahh, just what I am looking for PeteL and Ronin, I am keen to make my own, I was just trying to find some bits but I will spend some time reading espresso-restorations
    Btw Ronin, what model is that a picture of?
    many thanks
    Lee
    That is a La Marzocco GS. First of the paddles I think. About 35 yrs old and is not in that condition now. Completely striped, cleaned and currently re wiring.
