Im restoring an old Brasilia Portofino from 2003. Ive managed to seal all the leaks and Ive descaled it.
Now to the problem. The brew pressure is only 4 bar , even though I tried to adjust it on the pump it doesnt go higher. Ive descaled the pump , with no luck.
Could be a problem with the manometer ? Because i get about 60ml from the portafilter on 10sec, which is a good flow rate or? Or could it be the pump that needs to be replaced?
