Originally posted by valimar
View Post
View Post
Now you'll need a couple of M3 (?) roundhead screws to put it in place, cleaning the spot where it goes with alcohol or thinner first.
Don't forget to use some (dense) thermal grease between the heating element manifold and the bottom of the thermostat to ensure good heat transfer and well insulated female spade terminals for the connection.
Now you're all set. =-)
CIV
) the problem with auto-reset cutouts is that if you've got a Pstat failure (though that looks like a Sirai 'stat so it's a whole lot less likely) they'll cycle the element, on until break temperature, off until reset temperature, which isn't really healthy for, but if all else fails it'll do.
