Hi All,
I own a La Cimbali M8 Selectron that has been working well for a couple of years however over time it has been starting to exhibit some worsening behavior. Currently the element switches off when its only a few cm into the blue on the pressure gauge whereas in the past it used to stay on until it was into the green. If I leave it on long enough it very slowly (hours) makes it way up to the green section after many on then off cycles.
Wondering if someone can give me any advise on what they believe the issue may be? Is it something easily fixed or do I need to get someone in to take a look?
Thanks in advance.
Thanks in advance.
