Semi auto 1 group with auto steam?
  • Gman01
    Originally posted by blend52 View Post
    Commercial ESE pods are paper not plastic.
    Good to know
    Sorry but no,....
    A Super Auto may not make the best coffee, but it may well be a better & more consistent result than a novice on good equipment.
    But dont take this as a suggestion to get a Super Auto, simplyt as a "heads up" that good equipment does not guarantee good coffee.
    hmmm, maybe not. But at least I'll be able to get some ripper shots out of it
  • blend52
    Originally posted by Gman01 View Post
    Aside from this, is Andy's point about the environmental impact of the plastic waste from all those pods.
    From my experience, good beans + good equipment + poor skill is still a better result than a superauto.
    Anyone disagree? Had a good experience with a superauto?
    Sorry but no,....
  • Gman01
    thanks for the responses. I appreciate the check of my logic/sanity.
    I think I'm going to forget about the auto temp steam arm function and just get one of those jugs with heat spot on it so that the noobs wont overheat the milk.
    I'm still confident that a commercial machine with mazzer auto grinder will be the best for this application.
    The pod machines can be ok for a small office, however the cost soon stacks up and we have a few short black drinkers who will really appreciate a well pulled shot. Aside from this, is Andy's point about the environmental impact of the plastic waste from all those pods.
  • Dragunov21
    It takes a little finesse to get good microfoam, but f-all to get better stuff than an autofrother will put out. I did it first time just by doing what I said earlier.
    Milk temp is reasonably important, I find. You need to texture milk properly to make it sweet, sure, but IME overheating will kill the sweetness as well as the texture.
    Remember, they don't have to be getting a GOOD coffee, just one that's better than the crappy pod coffee they're used to. As long as no-one's complaining that it's worse, then it's all good because the others have the option to make good coffee if they can be bothered. Besides; no reason you couldn't run a Pixie alongside it to cater for the DILLIGAF crowd; it's hardly gonna make a dent after the first $3400...
  • blend52
    Other than posibly more imposing,..its no more complicated than say the BDB ...but all Semi-Auto machines need a little more skill than say a Nespresso, or a fully auto. With a random user base of say 20 workers in an office, how may do you think really want to aquire the skills to grind / brew /steam milk etc etc in order to make a GOOD coffee. ?......
    .. . But really, just saying , milk temperature is a trivial issue compared to the host of other variables in the process of making a good cup.
  • Dragunov21
    Sincere question (not a challenge); how is it more complicated than any proper semi-automatic machine?
  • blend52
    Originally posted by Dragunov21 View Post
    Ah, my mistake; I should've read the first post properly.
    How many people in the office? Few enough that it'd be feasible to get them together in a group and show them "Stick tip under right next to the jug edge, turn on steam, lift until you hear slight tearing then keep it there until the jug's too hot to hold"?
    Might not produce art-quality foam but it should produce better results than an autofrother for 90+% of people.
    And as i said ... milk temperature will be the least problem of any untrained "office barista" using a commercial type machine & grinder.
    Training will be essential, and milk texturing should be part of that training.
    PS: have you considered a m/c that has a separate PF that can also use ESE commercial pods as well as fresh ground. ?
  • Dragunov21
  • Gman01
    Struggling to understand how you could drop that kind of money on a machine yet not care enough to manually steam...
    Bit like getting a $90k sportscar and getting the optional base-level-commodore autobox installed.
    I can certainly appreciate the sentiment. This is not the sort of machine most coffee snobs would buy for that money, but this machine is for an office and as such must satisfy a number of users. The company is paying so cost is not so much an issue. But I cant bring myself to buy another superauto. I'd rather drink tea. I was originally looking at the officine brugnetti which is a two group/two wand setup with a temp sensor on one of the wands to auto shut off steaming milk at the correct temperature, which would be ideal for noobs. Only prob is we are running out of bench space, and can probably only fit a single group machine.
    Looks like i may have to forget about this idea and just go with a regular single grouper.
  • Dragunov21
  • Gman01
    Originally posted by chrislng View Post
    Might consider a La Pavoni Verobar Volumetric
    •Stainless steel boiler (2 litre) with horizontal heat exchanger
    •Pressurestat to maintain constant boiler pressure
    •Removable water tank (2.9 litre)
    •Pump pressure: 15 bar
    •Pump pressure gauge
    •Boiler pressure gauge
    •2 stainless steel steam nozzles
    •Adjustable hot water tap
    •Chrome plated brass group handle
    Optional automatic milk frother
    I did see this one as well, which looked interesting. Although from the user manuals pdfs that I downloaded, the optional milk frother was a kind of lazy attachment turbo frother that you just sit the jug in. I was really after the traditional steam wand with temperature sensing cutoff.
    Apparently these can be retrofitted to machines. Maybe I will have to go this way.
  • Gman01
    Originally posted by DavidK View Post
    Nuova Simonelli has an autosteam wand option for many models, eg have a look at the Appia brochure. Similar may be available on other brands as well
    Yes, this is one that I am looking at. Apparently the Australian distributor only has the non-autosteam arm in stock. They are chasing up a price for me.
  • chrislng
  • DavidK
  • blend52
    I recall the Iberital L'Anna Handy has been recommended and used in similar situations by some on this forum,..with good feedback.
