LM Gs3 + Mini Mazzer + Bad barista skills
  • LM Gs3 + Mini Mazzer + Bad barista skills
    Hi guys. Ive had my GS3 for one month now, along with my mini mazzer doserless. Firstly, the machine is beautiful and Im sure, capable of everything I've read on here about that setup. It should be.
    My barista skills are not. Ive gone to a basic course, and had someone come around to go through things with me. Unfortunately nothing seems to have helped.
    I am fine with any shot containing milk, which hide my shot errors. I'm trying to perfect my short blacks and won't even try the famed ristretto as yet.
    I have put through 550 grinds on my mini mazzer so it seems, but probably not really that much as I find I am continually adding more than my "calibrated" double shot. I'm using a bottomless (as of two days ago) with the 14g basket.
    So here is my sequence: Assume Ive pulled a couple shots already so grinder is primed etc. Beans are never more than 10 days old and are from specialty boutiques or local roasters.
    Equipment: Mini Mazzer doserless, timed version. LM GS3 Manual Paddle version running from the tank. Using water from a local water thing (one of those 10L boxes, not distilled)
    1. Grind directly into portafilter. Lament over the clumping. Try to break up a few clumps. Weigh the grind. 15g into the 14g basket. This doesn't mound over the top so I settle the grinds by tapping the portafilter, and then tamp by feeling the edges of the tamper and the basket and pushing down with what feels like 30Lbs to me. In any case, I tamp in a similar way every time (I think). I clean the grind from the edges of the basket.
    2. I lock the portafilter in (Sits just before 6 o'clock so probably sitting where it should and is nice and firm).
    3. I preinfuse for 5 seconds (Only do this to try to reduce what I think is channeling)
    4. On full on the MP and watch the bottom of the naked portafilter. I get tiger striping, but also get early blonding. I stop it when the flow starts flowing more like water, and less like oily coffee (Supposedly the 3rd colour change)
    5. Disconnect portafilter, and purge.
    Taste: Usually sour as if under extracted. Tried making the grind finer, but end up choking the machine. Not getting the full 30mLs in 30s. More like 30mLs in 18 seconds. With my previous double shot portafilter, I would never get 2x 30mLs in 30s, and if I did, it definitely wouldn't be good coffee.
    Ive tried almost everything. I feel that it is a distribution problem. I tried the Weiss (WDT) method for distributing the grounds. I tried grinding directly into a container, mixing up the grinds and trying to break the clumps and then putting it into the portafilter. Nothing seems to be helping. I got some advice to remove the little grid (Not the mesh but the screwed in stainless steel grid) in the doserless funnel but this hasn't changed anything.
    I tried nutating, but didn't help. Got a very slow flow followed by a channeling. Tried settling the grind, over dosing significantly, and choked the machine. If I use 15g in the 14g basket, like I said above, it doesn't mound. Also when disengaging the portafilter, the top of the puck is quite wet suggesting that I am under dosing. My normal method was to follow the good coffee stores and disregard weighing, mound the grind, and sweep it flat, and then tamp. But this causes early blonding for me as I think my distribution is really off.
    I know that there is a lot of information here, but wondered if someone could advise me as to something else to try?
    I'm planning on finding some time to get into more training, but it seems like I'm really not making much progress. Ive searched through the internet for distribution tips etc, and have tried most of them with little success.
    Thankyou very much.
    Sounds like you are doing most things right. I'll make two suggestions and then let more experienced people jump in. Firstly, you can experiment with change in dose. You can either up dose and grind coarser or down dose and grind finer and see how your extractions progress. If your shots are tasting under extracted then perhaps try down dosing and grinding finer. The other thing is the temperature of your brew water. What have you set the PID for? Perhaps you could increase temperature and see if this improves extractions.
      Morning CW,
      Have a read through post #1 in this thread http://coffeesnobs.com.au/general-co...esso-home.html
      Lots of useful information there, it may well give you a clue.
      You say "Ive gone to a basic course, and had someone come around to go through things with me. Unfortunately nothing seems to have helped." was the person that came round able to produce acceptable results on your machine?
      The GS3 certainly has a good reputation so assuming its set up correctly there shouldn't be a problem.
        Hi cwliew and welcome to CS!
        Nice setup! To get yourself calibrated, use an 18 or 22 gm basket either naked or double spout. It's easier with a bigger dose.
        Set your grinder so that the shot chokes, as before, then start to make the grind more coarse, one adjustment at a time, until you get a decent shot.
        You will also have to adjust the timer on the grind setting of the mini-e as you adjust the grind, to compensate for volume change.
        When you make each adjustment of the grinder setting, purge at least two shots worth of grinds so that you are not lagging behind the adjustment you make, with
        the shot being poured..
        It will take 1-3 doses for the grind changes to appear in your filter basket. (3 on my Robur-e, not sure about the mini).
        There is currently a lot of misinformation/confusing information around re dose and tamping, use the link that Yelta has provided.
        Cheers.
          Originally posted by cwliew View Post
          ...I get tiger striping, but also get early blonding. I stop it when the flow starts flowing more like water, and less like oily coffee (Supposedly the 3rd colour change)...
          ...Not getting the full 30mLs in 30s. More like 30mLs in 18 seconds. With my previous double shot portafilter, I would never get 2x 30mLs in 30s, and if I did, it definitely wouldn't be good coffee...
          To me it's sounding more like a timing issue. You really need to cut it well before that watery stage. I manage to get 60ml in ~30s with now blonding at all, but that might also be because I use a 21g basket.
          I would keep playing with the dose/grind until you find the sweet spot you're after.
          It's a long journey to create a perfect shot, and equipment only does so much. The rest is up for you to perfect: fine tuning that grind/dosing/tamping technique. You'd be surprised how the finest of adjustments makes such a difference in the cup.
          Hope this helps.
          -Aaron
            Firstly, who else's mouth is watering at the thought of that combo? Secondly, the mini mazzer's adjustment collar is quite sensitive. One notch can easily mean 3 or more seconds. So with that in mind, I would definitely recommend following Yelta's link and go back to basics.
            Also if I was you, I would invest in a bigger basket. Sometimes with particular beans and roasts the flavours can only be tasted with a bigger dose and basket.
            Also, maybe some more advanced training for your high high class equipment couldn't hurt at all
            Let us know how you go!
            Michael
              Thanks for your comments. I will take a read through that link tonight.
              I have a 17g basket and a 21g as well as my impossible to use 7g single dose one which I've banished behind the instant coffee as punishment.
              All is not lost - I am making absolutely delicious milk coffees so I can at least be happy in the morning. But when I'm at home working, I prefer to just go shot after shot of delicious short blacks.
              I have been playing around with pre-infusion which seems to be helping a lot. On the MP version of the Gs3 it is very very sensitive, and a mm too much movement on the paddle activates the pump. Definitely the coffee is better when I pre-infuse, so I put this problem down to channeling.
              I need to find someone to come around to regulate the coffee more. The barista that I got around was someone to help me more with my milk side, so that side is at least 100% better, and I can make delicious milk every time now. The basic course was fine as it taught me the basic movements like purging to keep the thing clean and bitter bean free, and proper use of a machine and the basics of dialling it in.
              I will try to bigger baskets, but to be honest, I want to be able to use the machine in all aspects of it, rather than an up dosing workaround with a larger basket. The pursuit of perfection shouldn't be beyond this setup.
              mwcalder - my mouth waters all the time when I make coffee. I'm in love with the whole process.
              Will try changing the grind and dose, but thought I should be aiming for a constant 14g-15g no matter how coarse or fine in order to keep at least one thing constant.
              Chokkidog - will try that method. Seems like a good approach.
              To put things in perspective, I'm going through 250g daily with only me drinking it - that's about 12 double shots after a bit of purging of the grinder between adjustments and half of those shots end up down the sink after the first sip.
              Will keep at it and report any successes.
                Whenever I make black coffee at work I backflush and make sure it is all sparkly up there but I trust you already know/do this from your comments.
                Whatever basket you use, it's been designed for that dosage. Especially when it comes to VST and LM baskets so I find it helpful to stick to that dosage. It may be worthwhile just trying the bigger baskets and see what your palette prefers if you haven't done so yet. Also when you are setting your grind for 30mls in 35 seconds (I count the pre infusion) make sure your dosage is always the same shot after shot (scales are a definite help here) and your tamp is the same ei: double or single tamp/polish and so on.
                With the set up, there shouldn't be any reason that you can't pull a beautiful short black when you are at work. Maybe it's the beans??
                Good luck!
                Michael
                Btw: have you changed the grind during all of this? (dont mean to teach a grandmother to suck eggs but just covering absolutely all bases here )
                  Absolutely no reason that you won't be able to successfully dose @ 14gms.
                  Learning how to drive your gear will be easier at the start if you use your bigger filter basket.
                  In my experience they are a bit more forgiving, re channeling, when you are developing your personal technique.
                  Good luck!
                    Welcome cliew,
                    Why the issue with larger baskets? Surely not $$$ when you have spent over $7k??
                    Some coffees are just not suited to lower doses and if you restrict yourself to them, you will limit yourself and the coffee. FWIW, only tight@rS3 cafes will be using 14g in a double- so throw away the advice you have read or were given. It's yet more internet mumbo jumbo
                    My advice is that you will benefit from lessons to help dose and distribute consistently. In addition, palate work will help you to get the best from your coffee.
                    You have purchased a Ferrari. Now you need to learn how to drive it. Start in first gear.
                      Great advice. OK, its onto the 21g then from here onwards. Just to be perfectly correct on this, from a 21g basket, I should be extracting about 90mLs of coffee from a triple basket? If I'm using the bottomless portafilter, then that's fine, but 90mLs is a big shot. Otherwise, getting 30mLs from a 21g basket seems...wrong. Correct me here, as my understanding is that its 1 shot (7g) 30mLs. If you want a double, use the 14 or 17g and the double spout portafilter. 21g, for those who want it stronger but still a double.
                      I've been trying to get a single shot from a 14g basket, so perhaps that's my problem (i.e. more with understanding than actually early blonding)
                      I think some professional help might be required soon, or my machine might disown me.
                      I only back flush at the end of a session to clean it all, or after Ive done many consecutive shots, but never just before a short black. Ill give it a shot, but the taste doesn't suggest over extracted bitterness, but under extracted sourness.
                      More tries tonight.
                        Had similar issues with "transitioning" to my GS3.
                        In hind sight it was really a combination of just getting used to my new baby - but more importantly working out the finer details of the VST baskets. Being anal retentive - I always want perfection ......
                        Settled on the 17g basket, a finer grind and a lighter tamp. Depending on the coffee, often nothing for between 8-9secs then what I would have previouy thought as a pour that was just a bit too tight. But it gives the taste that I am after.
                        Gotta confess - I am not a purist of brew ratios etc. I prefer to simply do - and adjust to acheive what I want to taste. So I tend to toss the 30ml stuff out the window.....call me a heretic but I have been using tight pours and up to 40 secs to get what I want.
                        I use a similar pre-infuse time ( the gurgles on mine the give away). I have upped the brew temp slightly as well.
                        The big game changer for me was talking the "taste tester / all round wonder woman" into allowing a Robur on the bench at home. The difference in consistancy between the mini and the robur is more than you would ever expect. The dosing of the robur to the vst works almost perfectly when the grind is correct - I used to find the mini a bit fluffier and basket tended to be a little underweight at correct grind. For consistancy - I weigh my portafilter load.
                        Stick with it grasshopper - it comes together.
                        I think the key here is that everyone has chipped in some fantastic advice - try some of the info - and formulate your process to achieve your results.
                        "Operator error" is not an option! You will succeed!
                          My advice, keep it to 30-60ml max from anything 14g and upwards basket size. Best bet is to just choose one basket to work with rather than playing with so many variables that you don't know what's happening. I'd suggest a standard double.
                          Baby steps when starting off, not advanced barista techniques.
                          Also worth having a look at Scottie do his thing for some good pointers.
                            Good luck cliew. The only thing I can add is not to get too hung up on the weight of the grinds. Shower screen heights differ, beans differ in their density etc. Work out an appropriate dosing level for your machine (and there's a bit of flexibility there) and adjust grind to suit. Seems to be the most consistent method for me and I believe many others....but note, for my machine (Diadema Reale) this results in about 20.5-21.5g in a *nominally* 15g double basket (less in a VST though). I weigh the grinds for the purpose of consistency within one particular bag of roast beans....not across beans (and even then it changes as beans age / humidity changes). And most of all....have fun learning what works for you.
                              Exactly my experience when I switched to VST baskets. I thought that the first shot was going to be over extracted but turned out to be delicious.
