In Brief
A new model (and brand!) from an established espresso machine manufacturer.
The Profitec brand
Profitec is the company that manufactures the "ECM Manufacture" brand of machines (Technika, Controvento etc). The company has put it's own name to a new line of machines and the Pro 700 is the first of these.
Pro 700 Highlights
A PID controlled dual boiler which can run off it's internal tank or be plumbed.
Specification
The Profitec brand
Pro 700 Highlights
Specification
- Dual boiler
- PID-display for the individual temperature adjustment of both boilers
- PID-display indicates the brewing time in seconds
- E61 brew-group
- Rotary pump
- Wear-free rotary valves (spring loaded so user can't over tighten)
- Cool touch steam and hot water wands
- Separate grid to raise cups
- Boiler and pump pressure gauges
- Stainless steel boiler with 0.75 l volume for espresso preparation
- Steam and hot water boiler in stainless steel with a 2.0 l volume
- Steam boiler with separate on/off switch
- Boiler insulation
- Two heaters with 1 x 1200 Watts and 1 x 1400 Watts
- Switchable from water tank to fixed water connection
- Water tank with a 3 l volume and water tank connector
- Automatic shut-off by way of low water volume sensor
- Large drip tray with a 1 l capacity
- Removeable cup tray
- Voltage 230V
- Weight 31 kg
- Dimensions W x D x H: 340 x 475 x 420 mm without portafilter
- 340 x 590 x 420 mm with portafilter
