Hi guys my dues steam wand started to leak steam. I just replaced the inner valve seal. No good. Took it apart and cleaned. No good. Got in there with sand paper and cleaned. Marginal improvement. Still slight leak. Didnt replace small oring on plunger as it looked fine and any leak there comes out at handle not the wand....is it just a case of having to replace the entire valve block...does the brass get wear and cannot seal the black rubber seal any more?
