classe 8 rebuild.
  • classe 8 rebuild.
    thought i would share my newest project, a completely disassembled rancilio classe 8. It came as a frame some steel and boxes of parts and small plastic bags. Everything is numbered but the numbers didntt seem to make any sense. It was apparently dissembled to be moved and then never re assembled for what ever reason.
    Some were badly scaled , im not sure how the machine worked at all with the HX injectors being almost completely clogged with scale.
    finally got some ambition and got the frame powdercoated and started the re-assembly. so far the only thing i seam to be missing is the rubber stand off mounts for the pump. going to attempt to convert the steam valve to the c-lever system as well.
