Hi guys
Long time first time!
I have the above machine and made the mistake of turning off the machine for 6 months leaving the boilers full of water.
It has been a long and slow process getting the machine back on track.
When the machine was switched back on, it's performance dropped over a few weeks.
In short I have replaced the
pump (as the old was only producing 6 bar)
Pump check valve
Numerous orings and seals throughout the unit where leaks occurred. (Head, top and bottom only, vac breaker, steam wand)
The final problem I have not been able to sort.
Run the pump, up to pressure 9 bar
Switch off
And the pressure gauge starts to drop
After 90 seconds 5 bar
10 minutes down to 1 or 2 bar.
I have replaced the pump check valve, no water appears to be going into the drip tray.
As soon as I start the pump it's up to pressure within 2 seconds.
Where is the gauge taking it's reading from and could I be losing pressure there.
Any feedback would be appreciated
Pump check valve
Switch off
