Hey guys!
So I'm trying to get a Synesso up and running in a mobile setup.
I'm having a problem with the pressure staying stable throughout the shot.
I'm using the Flojet Water Dispensing System, but it seems to be "pulsing" which is in turn making the pressure jump up and down.
I can see it on the pressure gauge as it's moving around instead of staying stable at 9 bars.
Currently the setup is as follows:
Water Bottle--> Jetflow Water Dispenser --> Water Filter (3M highflo series)--> Synesso Pump
So I'm wondering if you can see any obvious flaws in my setup, or have any tips to try and rectify the
problem?
The Jetflow is supposed to deliver a steady 40PSI but perhaps the water filter is causing an issue and needs to be moved in the chain?
Another thing to note is the pipe from the Jetflow to the filter is rather long. Perhaps an issue there?
Anyway, if anyone has any ideas I'd greatly appreciate it!
Warm regards,
Geoff
problem?
Warm regards,
Geoff
