I had a good look around a lot of forums and the advice seems conflicting and not very clear. I've had my Junior R for 3 years now, but filling up the tank by hand is getting a bit boring when we're busy and I was always told that I can plumb the machine into the mains. Easy for me to do that, but how and where to connect the water?
One post I read said that it was designed to work with the tank still attached - keeps it simple I suppose, but what happens to the old water in the tank?
I've taken some pics of the guts of the machine to see if someone can tell me what to do.
This first pic show two pipes with filters on the end that sit in the water tank when it's in place.
The pipe on the right disappears off to a round plastic device (see pic below) that presumably detects the presence of water in the tank and shuts it off if the pressure is too low?
The pipe on the right with the plastic filter on it goes to what looks like a little pump located underneath the boiler - see pic below:
If you follow the braided hose on the other side of this pump, it goes off to a brass T and a plastic pipe goes off to what must be a valve and thence to the boiler.
The other side goes around towards the front of the machine to another brass T. On the opposite side of this T is a pipe to connect a hose to (see the last pic)with a screw above it which, presumably lets water in or out of this pipe if you back off the thread.
Could this be where I connect my mains to and leave everything else in place? Or am I barking up the wrong tree and need to do something completely different (could this just be a drain for the boiler or something?) like just connect the mains to both the pump and the device for detecting the presence of water in the tank?
If anyone else has done this mod and could point me in the right direction it would be much appreciated.
