plumbing-in Alex Duetto, ?? justifiable
  • #16
    this is very helpful,
    I'm redoing my kitchen,
    and looking at plumbing as well,
    hope I'm not hijacking thread
    does anyone have a photo to share of hole placement on bench, (towards back?, where does it need to align with machine), eventually looking to upgrade to Duetto,
    but want to organise plumbing while kitchen is being done.
    how large must the hold in the stone be?
    can it go via the splash back instead?
    and do you need two hole?, one for drainage and one for water supply.
    and what is this thing about the PLV,
    thanks
    • #17
      Definitely through the bench is easier for drainage purposes. I generally cut a 60mm hole as most cable caps are made to suit 60mm holes. Cable caps are basically a plastic or metal ring that sits over the hole to protect the edge and save your hoses from cutting on the stone. A plv is a pressure limiting valve and it does just that. It basically prevents a spike in the mains that could potentially destroy your machine!
      • #18
        Great advice. Thanks
        • #19
          thanks for the tips
